[Qgis-community-team] Coding and compilation guide 1.6.0
    jr.morreale at enoreth.net
    Mon Jan 17 03:44:01 EST 2011
 Sorry, I didn't saw it was that one. Is a port needed ?
 On Mon, 17 Jan 2011 09:40:40 +0100, Otto Dassau <dassau at gbd-consult.de>
 wrote:
> Hi,
> the coding and compilation is not moved to pdflatex. So you need
> ImageMagick's convert installed, as Jürgen wrote.
> Regards,
>  otto
> Am Fri, 14 Jan 2011 09:38:03 +0100
> schrieb MORREALE Jean Roc <jr.morreale at enoreth.net>:
>> Le 13/01/2011 22:40, emperor Stef a écrit :
>> > Hello !!!
>> > I am trying to build the translation and I get errors when typing
>> > "make" ... specifically I get make[2]: convert: Command not found
>> > make[2]: *** [cpp1_application.eps] Error 127
>> > It does not compile at all... I get the same error when I type
>> "sudo
>> > make"
>> > Why is this happening?
>> > Regards,
>> > Stefanos
>> Hi, converting to *.eps is not necessary since we moved to pdflatex.
>> Copy the following line in .sh file and it should be ok :
>> #! /bin/sh
>> cd /home/user/path/to/QGIS/1.6/user_guide/
>> # clean the folder of previous builds
>> rm -rf *.aux *.bbl *.blg *.idx *.ilg *.ind *.lof *.log *.lot *.toa
>> *.toc
>> *.synctex*.gz *.html *.4ct *.4tc *.css *.dvi *.idv *.tmp *.xref *.lg
>> # build the manual with bibliography and index
>> pdflatex user_guide.tex
>> bibtex user_guide
>> makeindex -cl -o user_guide.ind user_guide.idx
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
