[Qgis-community-team] Coding and compilation guide 1.6.0
Otto Dassau dassau at gbd-consult.de
Mon Jan 17 03:40:40 EST 2011
the coding and compilation is not moved to pdflatex. So you need
ImageMagick's convert installed, as Jürgen wrote.
Regards,
 otto
Am Fri, 14 Jan 2011 09:38:03 +0100
schrieb MORREALE Jean Roc <jr.morreale at enoreth.net>:
> Le 13/01/2011 22:40, emperor Stef a écrit :
> > Hello !!!
> > I am trying to build the translation and I get errors when typing
> > "make" ... specifically I get make[2]: convert: Command not found
> > make[2]: *** [cpp1_application.eps] Error 127
> > It does not compile at all... I get the same error when I type "sudo
> > make"
> > Why is this happening?
> > Regards,
> > Stefanos
> Hi, converting to *.eps is not necessary since we moved to pdflatex.
> Copy the following line in .sh file and it should be ok :
> #! /bin/sh
> cd /home/user/path/to/QGIS/1.6/user_guide/
> # clean the folder of previous builds
> rm -rf *.aux *.bbl *.blg *.idx *.ilg *.ind *.lof *.log *.lot *.toa *.toc
> *.synctex*.gz *.html *.4ct *.4tc *.css *.dvi *.idv *.tmp *.xref *.lg
> # build the manual with bibliography and index
> pdflatex user_guide.tex
> bibtex user_guide
> makeindex -cl -o user_guide.ind user_guide.idx
More information about the Qgis-community-team mailing list
