[Qgis-community-team] User guide patch
Otto Dassau
dassau at gbd-consult.de
Mon Mar 21 10:30:39 EDT 2011
Hi Alister,
thanks a lot for your patch. I committed it to the repository.
regards,
Otto
Am Mon, 21 Mar 2011 22:48:31 +1300
schrieb "Alister Hood" <alister.hood at synergine.com>:
> Hi everyone,
> Attached is another patch, removing the incorrect paragraph on layer
> groups, and also rewriting the correct paragraph to add some more
> details.
> Regards,
> Alister
> > -----Original Message-----
> > From: Alister Hood
> > Sent: Friday, 11 March 2011 8:30 p.m.
> > To: 'Werner Macho'; qgis-community-team at lists.osgeo.org
> > Subject: RE: [Qgis-community-team] User guide patch
> > Ah.
> > There was one thing I forgot. This paragraph is incorrect and should
> be
> > deleted:
> > "If several vector data sources have the same vector type and the same
> > attributes, their symbolisations may be
> > grouped. This means that if the symbolisation of one data source is
> changed,
> > the others automatically have
> > the new symbolisation as well. To group symbologies, open the right
> click menu
> > in the legend window and
> > choose Add Group I . The file groups of the layers appear. It is now
> possible
> > to drag a file from one
> > file group into another one. If this is done, the symbologies are
> grouped. Note
> > that QGIS only permits the drag
> > if the two layers are able to share symbology (same vector geometry
> type and
> > same attributes)."
> > As far as I can tell there is no way to connect the symbologies of
> different
> > layers - I guess this paragraph
> > should have been deleted when the previous (correct) paragraph on
> grouping
> > layers was written.
> > Actually, I think the first (correct) paragraph on layer grouping is
> in the
> > wrong place - it should be moved
> > down below the lists of functions in the right-click menu, to replace
> the
> > incorrect paragraph.
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Davenstedter Str. 60 , D - 30453 Hannover , Germany
Phone: +49-(0)511-2615322 , Fax: +49-(0)511-2615323
Community Advisor - QGIS Project Steering Committee
More information about the Qgis-community-team
