[Qgis-community-team] User guide patch
Alister Hood
alister.hood at synergine.com
Mon Mar 21 05:48:31 EDT 2011
Hi everyone,
Attached is another patch, removing the incorrect paragraph on layer
groups, and also rewriting the correct paragraph to add some more
details.
Regards,
Alister
> -----Original Message-----
> From: Alister Hood
> Sent: Friday, 11 March 2011 8:30 p.m.
> To: 'Werner Macho'; qgis-community-team at lists.osgeo.org
> Subject: RE: [Qgis-community-team] User guide patch
> Ah.
> There was one thing I forgot. This paragraph is incorrect and should
be
> deleted:
> "If several vector data sources have the same vector type and the same
> attributes, their symbolisations may be
> grouped. This means that if the symbolisation of one data source is
changed,
> the others automatically have
> the new symbolisation as well. To group symbologies, open the right
click menu
> in the legend window and
> choose Add Group I . The file groups of the layers appear. It is now
possible
> to drag a file from one
> file group into another one. If this is done, the symbologies are
grouped. Note
> that QGIS only permits the drag
> if the two layers are able to share symbology (same vector geometry
type and
> same attributes)."
> As far as I can tell there is no way to connect the symbologies of
different
> layers - I guess this paragraph
> should have been deleted when the previous (correct) paragraph on
grouping
> layers was written.
> Actually, I think the first (correct) paragraph on layer grouping is
in the
> wrong place - it should be moved
> down below the lists of functions in the right-click menu, to replace
the
> incorrect paragraph.
Type: application/octet-stream
Desc: layer_grouping.patch
Url : http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20110321/80c98871/layer_grouping.obj
More information about the Qgis-community-team
