[Qgis-community-team] more rst conventions questions
    Otto Dassau
    dassau at gbd-consult.de
    Fri May  4 05:41:11 EDT 2012
for 1.
Until now we used to add a small hint to the figure caption, e.g. (KDE) or
(OSX) or (GNOME) .... Since we often work on QGIS Versions that are not
installed on the OSGeo Live DVD I am not sure, if it makes sense to use that.
for 3.
This is a good idea. As for http://qgis.org/pyqgis-cookbook/ we could add a
http://qgis.org/user-guide/. I can do that the next days.
Regards
Otto
Am Fri, 4 May 2012 17:21:20 +0800
schrieb maning sambale <emmanuel.sambale at gmail.com>:
> Hi,
> I have been editing several rst docs in the EN userguide the past
> week.  A couple of questions before continuing:
> 1. Updating screenshots - many of the screenshots needs to be updated
> since there are GUI changes made.
>   - What should be default OS for screenshots? Depending on the OS,
> some GUI appear different (especially with OSX).
>      I'm thinking we use Xubuntu/OSGeo Live DVD as the base OS for
> creating screenshots, this way, we have consistent
>      look of the screenshots within the user guide.
> 2. File location of icons and image screenshots - Each chapter has its
> own img directory for screenshots and icons,
>     however, the conf.py [0] contains global image aliases for some
> icons located in the user_guide/img directory.
>     - Is it possible to include all the commonly used icons in
> conf.py's rst_epilog so that these are available in all the chapters.
>       I am only using the English version of QGIS so, I'm not sure
> whether icons are different with the other languages.
> 3. Compiled rst available - do we have a regular build of the rst
> documentation available already? I do compile my own, but it would be
> good
>     if we have a daily build available in the qgis.org so that we can
> start linking QGIS questions to sections of the manual.  Even as a
> working draft.
> [0]
> https://github.com/qgis/QGIS-Documentation/blob/master/user_guide/conf.py#L90
More information about the Qgis-community-team
