[Qgis-community-team] rst2pdf.pdfbuilder (exception: No module
named roman)
Otto Dassau
dassau at gbd-consult.de
Mon May 21 03:44:04 EDT 2012
Am Sat, 19 May 2012 17:13:28 +0200
schrieb Paolo Corti <pcorti at gmail.com>:
> On Sat, May 19, 2012 at 2:22 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
> > Hi,
> > I wanted to do some rst conversion but fail with error message:
> > Could not import extension rst2pdf.pdfbuilder (exception: No module named
> > roman)
> > It seems necessary to upgrade Sphinx v1.1.2 which I think is not that
> > old. Is it always necessary to have the latest version available to be
> > able to work on the documentation? Or is there another work around?
> Hi Otto
> It seems to me that your system is missing rst2pdf, which is based or
> ReportLab. If you do a pip install rst2pdf in your virtualenv or system it
> should start working
> ciao
> p
Hi Paolo and Yves,
no it is all installed. I guess it is just too old :(. I will have a look to
use a virtual environment.
Thanks and Regards
Otto
More information about the Qgis-community-team
