[Qgis-community-team] rst2pdf.pdfbuilder (exception: No module
named roman)
Paolo Corti
pcorti at gmail.com
Thu May 24 08:40:34 EDT 2012
On Mon, May 21, 2012 at 9:44 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi Paolo and Yves,
> no it is all installed. I guess it is just too old :(. I will have a look to
> use a virtual environment.
Hi Otto
I have got in same shoes today.
After some investigating, it seems that newest docutils version (0.9)
generate this issue.
So try doing this in your virtualenv (or system):
pip uninstall docutils
pip install==0.8.1
and the issue should be solved.
I have also added a requirements.txt file, so it will be easy to
update the virtualenv to my same one:
pip install -r requirements.txt
note, though, that as of today the pdf build is failing for some reason.
ciao
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the Qgis-community-team
