[Qgis-community-team] web/doc site structure
Werner Macho
werner.macho at gmail.com
Wed Nov 21 00:04:37 PST 2012
Hi!
I don't know if it is necessary to build a pdf - but libsphinx was missing
on the server..
I updated it (together with some new libtiff packages).
The only disadvantage for now (until we have a new website) is that php
have to stick to the version which is now installed on the server (and
should not be updated) because otherwise joomla would not run (or would
react strange).
But I guess we would not need php5 andymore when we have the new webpage ..
There are also a lot of "Obsolete and Locally Created Packages (40)" on the
Server .. I don't know if these packages are still used somewhere or we can
clean them (gcc among them - do we compile something on the server?)
and +1 for having another admin taking care of the docs on the server
(Richard)
kind regards
Werner
On Wed, Nov 21, 2012 at 8:16 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
> Hi,
> Am Tue, 20 Nov 2012 23:00:06 +0100
> schrieb Paolo Corti <pcorti at gmail.com>:
> > Hi Richard
> > > I have been trying to create a tree with two stems:
> > > docs
> > > website
> > > But this broke the poodle stuff (I think). I do not have access to the
> > > server, so I cannot fix it myself.
> > It is just a matter of soft-linking the .po files from the Pootle
> > directory. BTW, I would be +1 to give you access to the server
> I would also be +1 to provide access to the server for Richard.
> > > So please help or give some input to decide:
> > > - is the division in docs/website nessecary or only bloat (we can
> easily
> > > go back to the version without website stuff)
> > I like the new division
> > > - should we decide for ONE translation process (eg only poodle, because
> > > you need the least technical knowledge (as a translator))
> > I would go for both approach. At least we should test it for a while,
> > maybe for just a project, and see if there is any drawback.
> > > - why is the documentation not rebuild every day (crontab is failing?)
> > I have no idea. I knew Otto had solved it.
> The html builds again every 4 hours. The pdf has a problem - don't know why
> yet but I will fix that tomorrow...
> Regards
> Otto
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20121121/6962b025/attachment.html>
More information about the Qgis-community-team
