[Qgis-community-team] web/doc site structure
Otto Dassau
dassau at gbd-consult.de
Tue Nov 20 23:16:34 PST 2012
Am Tue, 20 Nov 2012 23:00:06 +0100
schrieb Paolo Corti <pcorti at gmail.com>:
> Hi Richard
> > I have been trying to create a tree with two stems:
> > docs
> > website
> > But this broke the poodle stuff (I think). I do not have access to the
> > server, so I cannot fix it myself.
> It is just a matter of soft-linking the .po files from the Pootle
> directory. BTW, I would be +1 to give you access to the server
I would also be +1 to provide access to the server for Richard.
> > So please help or give some input to decide:
> > - is the division in docs/website nessecary or only bloat (we can easily
> > go back to the version without website stuff)
> I like the new division
> > - should we decide for ONE translation process (eg only poodle, because
> > you need the least technical knowledge (as a translator))
> I would go for both approach. At least we should test it for a while,
> maybe for just a project, and see if there is any drawback.
> > - why is the documentation not rebuild every day (crontab is failing?)
> I have no idea. I knew Otto had solved it.
The html builds again every 4 hours. The pdf has a problem - don't know why
yet but I will fix that tomorrow...
Regards
Otto
More information about the Qgis-community-team
