[Qgis-community-team] web/doc site structure
Otto Dassau dassau at gbd-consult.de
Thu Nov 22 01:24:43 PST 2012
Am Wed, 21 Nov 2012 09:06:11 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 11/21/2012 08:16 AM, Otto Dassau wrote:
> >>> But this broke the poodle stuff (I think). I do not have access to the
> >>> server, so I cannot fix it myself.
> >> It is just a matter of soft-linking the .po files from the Pootle
> >> directory. BTW, I would be +1 to give you access to the server
> > I would also be +1 to provide access to the server for Richard.
> Yes, please. I'll be gentle.
> I will also fix the pootle links then.
> >>> - why is the documentation not rebuild every day (crontab is failing?)
> >> I have no idea. I knew Otto had solved it.
> > The html builds again every 4 hours. The pdf has a problem - don't know
> > why yet but I will fix that tomorrow...
> I would say once or twice a day is sufficient. The building process of
> ALL languages is cpu heavy and takes a pretty long time already.
ok, I will change to once a day - you are right...
Otto
More information about the Qgis-community-team mailing list
