[Qgis-community-team] update from translated files
Otto Dassau dassau at gbd-consult.de
Wed Apr 17 03:11:26 PDT 2013
Am Wed, 17 Apr 2013 11:49:09 +0200
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi Otto,
> > it is build 3 times a day. Does it build correctly on your local PC? Have
> > you checked that?
> yes I checked and for some files I receive errors:
> i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_gui.po:125: le
> voci "msgid" e "msgstr" non finiscono entrambe con "\n"
>      msgfmt: trovato 1 errore fatale
> I'll fix it as soon as possibile.
> But the qgis_browser file I don't receive any error and is still doesn't
> appear in the documentation:
>      Compiling messages to
> i18n/it/LC_MESSAGES/docs/user_manual/qgis_browser/qgis_browser.mo
>      17 messaggi tradotti.
> I also controlled on my github and on the master on (manual_en_1.8
> branch) and the files are there...
I found those errors in master and 1.8 build...
msgfmt: found 2 fatal errors
101 translated messages, 8 fuzzy translations.
i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.mo
i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:128:
`msgid' and `msgstr' entries do not both end with '\n'
i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:141:
i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:177:
i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:622:
`msgid' and `msgstr' entries do not both end with '\n' msgfmt: found 4 fatal
errors
it can happen that the build script stops completly, if there are errors.
btw: looking at the logfiles I saw that there are many errors also in other
rst and translation files for the website, pyqgis_cookbook etc...
Therefore I would kindly ask everybody to build and check their changes,
fix errors and warnings and then commit. Otherwise it is hard to keep the
system runnning.
Regards
Otto
More information about the Qgis-community-team mailing list
