[Qgis-community-team] update from translated files
Otto Dassau
dassau at gbd-consult.de
Wed Apr 17 03:35:22 PDT 2013
Am Wed, 17 Apr 2013 12:23:29 +0200
schrieb matteo <matteo.ghetta at gmail.com>:
> > I found those errors in master and 1.8 build...
> > msgfmt: found 2 fatal errors
> > 101 translated messages, 8 fuzzy translations.
> > Compiling messages to
> > i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.mo
> > i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:128:
> > `msgid' and `msgstr' entries do not both end with '\n'
> > i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:141:
> > i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:177:
> > i18n/it/LC_MESSAGES/docs/user_manual/introduction/qgis_configuration.po:622:
> > `msgid' and `msgstr' entries do not both end with '\n' msgfmt: found 4
> > fatal errors
> > it can happen that the build script stops completly, if there are errors.
> Ok I will correct all the errors and then I re-commit the files.
> > btw: looking at the logfiles I saw that there are many errors also in
> > other rst and translation files for the website, pyqgis_cookbook etc...
> Where are the logfiles located? So I can have a look and maybe correct
> them..
> > Therefore I would kindly ask everybody to build and check their changes,
> > fix errors and warnings and then commit. Otherwise it is hard to keep the
> > system runnning.
> You are right, but i was sure there were not errors in build.
> Thanks
> Matteo
You can write your own logfile locally if you do:
sh scripts/post_translate.sh > /tmp/build.log 2>&1
Regards
Otto
More information about the Qgis-community-team
