[Qgis-community-team] Screencaps and 2.0 user manual
Hien TRAN-QUANG hien.tranquang at gmail.com
Tue Aug 20 15:45:22 PDT 2013
Hello,
Thanks to Alexandre, new screencaps have been taken for 'print
composer' and 'working with vector layers' chapters.
New images are correctly integrated in the pdf user manual, but it
seems the screencaps are not correctly linked in the HTML pages
generated by Sphinx : new images (saved by Alexandre in
/resources/en/user_manual/...) are not copied neither in /_static nor
/_images
Is it a bug or should the link I made in the rst file be changed ?
What I can't explain is that the PDF is correctly generated.
Hien.
More information about the Qgis-community-team mailing list
