[Qgis-community-team] Screencaps and 2.0 user manual
Otto Dassau
dassau at gbd-consult.de
Wed Aug 21 04:06:33 PDT 2013
Am Wed, 21 Aug 2013 00:45:22 +0200
schrieb Hien TRAN-QUANG <hien.tranquang at gmail.com>:
> Hello,
> Thanks to Alexandre, new screencaps have been taken for 'print
> composer' and 'working with vector layers' chapters.
> New images are correctly integrated in the pdf user manual, but it
> seems the screencaps are not correctly linked in the HTML pages
> generated by Sphinx : new images (saved by Alexandre in
> /resources/en/user_manual/...) are not copied neither in /_static nor
> /_images
> Is it a bug or should the link I made in the rst file be changed ?
> What I can't explain is that the PDF is correctly generated.
It seems to be a bug in the sphinx build environment, no worry about the rst
link at the moment.
Regards
Otto
More information about the Qgis-community-team
