[Qgis-community-team] git commands
Alexander Bruy alexander.bruy at gmail.com
Tue Feb 26 22:42:55 PST 2013
Hi Matteo,
On Tue, 26 Feb 2013 19:27:09 +0100
matteo <matteo.ghetta at gmail.com> wrote:
> Now, because the files are up to date all the time, what are the
> command for synchronizing my work directory with the translator
> leader?
if I understand you correctly, you need to add repo of your team
lead as remote to your local copy using
git remote add upstream git at github.com:...
Then, assuming that "upstream" is linked to team lead repository,
use
git fetch upstream
to obtain updates. And apply them to your branch with
git rebase upstream
Also I suggest to read excellent Git manual here
http://git-scm.com/book/
Hope this helps
Alexander Bruy
More information about the Qgis-community-team mailing list
