[Qgis-community-team] A note about "Lock layers" in documentation
andy aborruso at gmail.com
Mon Jan 7 09:01:49 PST 2013
Dear all,
thank you for your documentation work!
In "Adding a current QGIS map canvas to the Print Composer" paragraph -
http://goo.gl/mnjRw - you  have:
> To move layers within the map element select the map element, click the
>  Move item content icon and move the layers within the map element frame
> with the left mouse button. After you found the right place for an element,
> you can lock the element position within the print composer canvas. Select
> the map element and click on the right mouse button to  Lock the element
> position and again to unlock the element. You can lock the map element also
> activating the  Lock layers for map item checkbox in the Map dialog of the
> Map Item tab.
Probably I did not understand well, but reading this text it seems that
"Select the map element and click on the right mouse button" and
"activating the  Lock layers for map item checkbox " are the same thing. I
do not think that it is so. Am I wrong?
Thank you,
Andrea
Andrea Borruso
website: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus  <http://bit.ly/GEOplus>
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130107/740be395/attachment.html>
More information about the Qgis-community-team mailing list
