[Qgis-community-team] Doc translation and related issues
Marie Silvestre marie_silvestre at yahoo.fr
Mon Jan 7 12:40:15 PST 2013
I have just run the pre_translation script locally and it seemed to have worked: I now have a lot of fuzzy strings to update!
I have started on some files and commited them to test if everything is fine so it's a work in progress...
Regards,
Marie
 De : Marie Silvestre <marie_silvestre at yahoo.fr>
À : Otto Dassau <dassau at gbd-consult.de>; "qgis-community-team at lists.osgeo.org" <qgis-community-team at lists.osgeo.org>
Envoyé le : Lundi 7 janvier 2013 16h37
Objet : Re: [Qgis-community-team] Doc translation and related issues
Thanks Otto, I did my first merge without any problem!
I haven't tried to run the pre_translation script locally as I did not installed all the stuff needed. I can give it a try tonight.
Here is a simple example of untranslated (not synchronized) string from http://documentation.qgis.org/html/fr/docs/user_manual/preamble/features.html#features
I have this string in my fr features.po [1]:
msgid "**View data**"
msgstr "**Visualiser des données**"
While there is this string in the en features.po [2]:
msgid "View data"
msgstr ""[1] line 46 in https://github.com/qgis/QGIS-Documentation/blob/master/i18n/fr/LC_MESSAGES/docs/user_manual/preamble/features.po
[2] line 40 in https://github.com/qgis/QGIS-Documentation/blob/master/i18n/en/LC_MESSAGES/docs/user_manual/preamble/features.po
About the 2 links, they are not exactly the same... See QGIS gui pages:
http://documentation.qgis.org/html/en/user_manual/introduction/qgis_gui.html
http://documentation.qgis.org/html/en/docs/user_manual/introduction/qgis_gui.html
The corresponding po file [3] refers to a mix of the both links : line 32 is from the first link but line 47 is from the second, etc.
[3] https://github.com/qgis/QGIS-Documentation/blob/master/i18n/en/LC_MESSAGES/docs/user_manual/introduction/qgis_gui.po
Best regards,
Marie
 De : Otto Dassau <dassau at gbd-consult.de>
À : qgis-community-team at lists.osgeo.org
Envoyé le : Lundi 7 janvier 2013 13h29
Hi Marie and Richard,
Am Mon, 07 Jan 2013 13:17:56 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 07-01-13 11:19, Marie Silvestre wrote:
> > I'm back with a list of questions and remarks... (sorry!)
> No Problem !
> > First, it seems I do not have the rights to merge my last pull request
> > (https://github.com/qgis/QGIS-Documentation/pull/32) or I can't see
> > where to click...
> Tim is the admin for Github, I asked (email) him to give you commit rights.
I added Marie to the Github "QGIS Documentation" team.
> > Then I was wondering if the pre_translate script is running because some
> > strings have obviously been updated since the first translation but do
> > not appear in the po files (and these parts stay in English in the
> > doc...).
> I think it is
 (Otto?)
> Maybe I screwed up some files for you. Sorry. Because your first pull
> request I could not automatically merge anymore, so I have tried to
> merge it here locally via the pre en post scripts.
> Maybe I failed :-(
> Another option would be that there is a small change in the sentence?
> Maybe the po merge then fails, and falls back to the english version?
> Can you run the scripts locally? Is it working with you there?
> Or can you give me an example, so I can have a look here locally?
Can you please check, if there is some problem, Richard described above?
Usually it should work... if not, I will have a look
> > Do we have to fill the po files header?
> Not sure if it is good for something? If somebody thinks it is good,
> please stand up :-)
> Otherwise: maybe make it som general qgis header?
 There are 2 links for the doc :
> > http://documentation.qgis.org/html/en/user_manual/index.html
> > http://documentation.qgis.org/html/en/docs/user_manual/index.html
> > Which one is which?
> > (the first link is given in the QGIS-Documentation/readme.rst file)
> These are exactly the same.
> The first one is a apache rewrite rule for http://documentation.qgis.org
> Actually I think (after we filled the web site some more):
> http://documentation.qgis.org should point to a page like this:
> http://documentation.qgis.org/html/en/docs/index.html
> while
> http://www.qgis.org should point to
> http://documentation.qgis.org/html/en/index.html
yes, the URL sounds good :)
> > Finally I have found an error in the en doc (both versions!) :
> > http://documentation.qgis.org/html/en/docs/user_manual/introduction/qgis_gui.html#toolbar
> > "If you have accidentally hidden all your toolbars, you can get them
> > back by choosing menu option /Settings ‣ Toolbars ‣/."
> > Should be menu option "View" instead of "Settings".
> You could change it in the english version (that is the rst file
 that is
> in the sources directory).
> BUT be carefull with this. Because the names in the menus are different
> for different OS'es. I think what is written is valid for Linux. If it
> is different for Windows, we should maybe tell both ways?
This is not an error, because you View is GNOME and Settings is KDE etc. We
mentioned that in the QGIS_GUI section...
Regards
Otto
Qgis-community-team mailing list
Qgis-community-team at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130107/d563e4cc/attachment.html>
More information about the Qgis-community-team mailing list
