[Qgis-community-team] pull req of translated files
    Otto Dassau
    dassau at gbd-consult.de
    Thu Jan 10 01:25:47 PST 2013
Hi Matteo,
I think think the build.sh script was originally created to build the docs
on the server. I added some small changes, so you can now use it to create
your docs locally - I guess we can improve that. Please update your repo
and type
sh scripts/build.sh it
For others, if they also use a virtual sphinx environment, you can change
the language to make it work in nl, de, jp, ...
Regards
Otto
Am Wed, 09 Jan 2013 17:39:15 +0100
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi guys,
> right now I made two pull requests of the Italian translated files
> (those with the syntax problem).
> I compiled the build.sh so I can see if the corrections I made were
> right, so:
> - although I translated all the strings of the po files, when I
> generated the html files (with build.sh), in those files some parts
> remain untranslated
> - the build.sh needs a lot of time because it generates the html file
> for all the languages. I changed the pre_ and post_translation scripts
> so I can make html files only for the language I want. Maybe should I
> add how to make these changes in the howto file? Can be useful?
> Regards
> Matteo
More information about the Qgis-community-team
