[Qgis-community-team] Manuals and help
Andreas Neumann
a.neumann at carto.net
Thu Jul 11 03:02:32 PDT 2013
Thank you Victor, Otto, Paolo and others for explaining the situation. Makes sense to me what you propose.
Andreas
Otto Dassau <dassau at gbd-consult.de> schrieb:
>Hi,
>I agree with Victors suggestion and his experience with the SAGA
>community.
>I think their community is just too small to handle this, so we should
>start
>our own project and tell them, that they are welcome to contribute. And
>it is
>great to see, that we already have some people to work on it - thanks a
>lot
>for your offers!
>I remember we also talked a while ago how to integrate SEXTANTE docs
>into
>the qgis manual apart from the help tab within the modules. Here I
>would
>also support the idea of having something extra, not directly part of
>the
>manual.
>My idea for the SAGA module docs is:
>* it should be part of the documentation repository under
> https://github.com/qgis/QGIS-Documentation/tree/master/source/docs
>* it should be written in RST with the same styles as the manual, so we
>can integrate it in the build/update/translation/... processes, like
>all
> other manuals
>https://github.com/qgis/QGIS-Documentation/tree/master/source/docs/documentation_guidelines
>* speaking for the manual I would still like to have kind of an
>introduction about SEXTANTE (we already have this) and then link to the
> extra SAGA manual. As we did/do it for the INSTALL.rst in the qgis
>sources, we could have this introduction as part the extra SAGA manual
>and
>just integrate it into the main qgis manual as a chapter. This should
>be
> no problem within the docs repo.
>* as a note for help pages from other applications, such as GRASS or
>GDAL,
>we should just link to their web pages and integrate it in the SEXTANTE
>help tabs as it is already done, I think. It doesn't make sense to
>spend
> more effort on this at this point.
> They are usually not translated but very well maintained, e.g for
> * GRASS -> http://grass.osgeo.org/grass64/manuals/index.html
> * GDAL -> http://www.gdal.org/gdal_utilities.html
>So, I would love to see that we keep this interaction between the qgis
>manuals and the SEXTANTE module help in mind. So we are free to mix our
>docs as needed and people find a consistent (infra)structure, if they
>want
>to contribute.
>Thanks
>Otto
>Am Thu, 11 Jul 2013 09:51:39 +0200
>schrieb Victor Olaya <volayaf at gmail.com>:
>> Samuel
>> Thanks for you contribution. However, those docs are generated
>> directly from the source code and do not have much information. Of
>> course, they can be extended, but that means that the source code has
>> to be modified in SAGA....which makes it impossible for people who do
>> not know C++ to contirbute to the code, plus it would be the SAGA
>> people who would handle contributions. Considering that they are not
>> very active even in their own community and that they do not use
>> github but a svn repo (that is, no pull request that are made
>> easily...but patches...), I see that as a huge barrier.
>> I prefer to have something external, RST-based, easy for everyone to
>> modify, and focused on how those algorithms should be used from
>> SEXTANTE. Let's be a little selfish on that. If we eventually have
>> good docs, I am sure the SAGA people will find the way of reusing our
>> docs and incorporate them in their structure. Then we can start
>> thinking about just taking them from upstream and coordinate with
>> them. Until that happens, let's keep things on our side to make it
>> easier.
>> Thanks everyone for you help- I plan to write some instructions about
>> how to collaborate and maybe a list of algorithms that are more
>> priority than others
>> I will keep you posted
>> Thanks
>> Victor
>> 2013/7/11 Paolo Cavallini <cavallini at faunalia.it>:
>> > -----BEGIN PGP SIGNED MESSAGE-----
>> > Hash: SHA1
>> > Il 11/07/2013 02:52, samuelmesa at gmail.com ha scritto:
>> >> I managedthroughasmallPythonscriptto getsomethehtml
>> >> helpofSAGAinthesextantsyntax:
>> >> Script [1]: http://paste.ubuntu.com/5863377/
>> >> Sextant html file [2]: http://goo.gl/Sr12A
>> >> But there are some html files with errors due to special
>characters
>> >> such as "/, (,)" in command names.
>> >> To test this help should only copy the folder in the path:
>> >> /usr/share/qgis/python/plugins/sextant/saga/
>> >> I hope this can be a small solution for the moment.
>> > Great, thanks a lot. This opens back the issue:
>> > * should we write our own docs, or
>> > * contribute back upstream (adding only docs for the things changed
>in
>> > sextante, as Victor outlined)?
>> > In the second case, how could we write the docs and send them?
>> > All the best.
>> > Paolo Cavallini - Faunalia
>> > www.faunalia.eu
>> > Full contact details at www.faunalia.eu/pc
>> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> > -----BEGIN PGP SIGNATURE-----
>> > Version: GnuPG v1.4.12 (GNU/Linux)
>> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> > iEYEARECAAYFAlHeYacACgkQ/NedwLUzIr4k8wCfXHoqDfwB/0YEmO8fbQayAtpz
>> > DtMAnjYCmxwx+2FPqyQTfGcqPw3Uxv0u
>> > =fq89
>> > -----END PGP SIGNATURE-----
>> > _______________________________________________
>> > Qgis-community-team mailing list
>> > Qgis-community-team at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>Geoinformatik Büro Dassau - http://www.gbd-consult.de
>FOSSGIS consulting , training , support and analysis
>Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
>Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
>Community Advisor - QGIS Project Steering Committee
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130711/ec52ebcd/attachment.html>
More information about the Qgis-community-team
