[Qgis-community-team] Manuals and help
samuelmesa at gmail.com samuelmesa at gmail.com
Thu Jul 11 07:08:01 PDT 2013
Victor, thanks for the explanation, I will be available to contribute also
in the construction of the documentation, I am an active user of QGIS +
SEXTANTE and I would be delighted to support them in this task..
Thanks,
Samuel Mesa.
2013/7/11 Victor Olaya <volayaf at gmail.com>
> Samuel
> Thanks for you contribution. However, those docs are generated
> directly from the source code and do not have much information. Of
> course, they can be extended, but that means that the source code has
> to be modified in SAGA....which makes it impossible for people who do
> not know C++ to contirbute to the code, plus it would be the SAGA
> people who would handle contributions. Considering that they are not
> very active even in their own community and that they do not use
> github but a svn repo (that is, no pull request that are made
> easily...but patches...), I see that as a huge barrier.
> I prefer to have something external, RST-based, easy for everyone to
> modify, and focused on how those algorithms should be used from
> SEXTANTE. Let's be a little selfish on that. If we eventually have
> good docs, I am sure the SAGA people will find the way of reusing our
> docs and incorporate them in their structure. Then we can start
> thinking about just taking them from upstream and coordinate with
> them. Until that happens, let's keep things on our side to make it
> easier.
> Thanks everyone for you help- I plan to write some instructions about
> how to collaborate and maybe a list of algorithms that are more
> priority than others
> I will keep you posted
> Thanks
> Victor
> 2013/7/11 Paolo Cavallini <cavallini at faunalia.it>:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Il 11/07/2013 02:52, samuelmesa at gmail.com ha scritto:
> >> I managedthroughasmallPythonscriptto getsomethehtml
> helpofSAGAinthesextantsyntax:
> >> Script [1]: http://paste.ubuntu.com/5863377/
> >> Sextant html file [2]: http://goo.gl/Sr12A
> >> But there are some html files with errors due to special characters
> such as "/, (,)"
> >> in command names.
> >> To test this help should only copy the folder in the path:
> >> /usr/share/qgis/python/plugins/sextant/saga/
> >> I hope this can be a small solution for the moment.
> > Great, thanks a lot. This opens back the issue:
> > * should we write our own docs, or
> > * contribute back upstream (adding only docs for the things changed in
> sextante, as
> > Victor outlined)?
> > In the second case, how could we write the docs and send them?
> > All the best.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.12 (GNU/Linux)
> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> > iEYEARECAAYFAlHeYacACgkQ/NedwLUzIr4k8wCfXHoqDfwB/0YEmO8fbQayAtpz
> > DtMAnjYCmxwx+2FPqyQTfGcqPw3Uxv0u
> > =fq89
> > -----END PGP SIGNATURE-----
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
   / v \
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130711/aabece90/attachment-0001.html>
More information about the Qgis-community-team mailing list
