Hi all, I noticed that the pdf file of the 1.8 manual has some trouble: if you look at page 215 (gdal plugin) the informations about the warp, extract and assign projection seem mixed. I'm translating from the .po file to Italian and the .po file doesn't have problem. Cheers Matteo
