[Qgis-community-team] sphinx trouble
matteo
matteo.ghetta at gmail.com
Fri May 17 01:05:40 PDT 2013
Hi guys,
as usually, before commit the translated files I build them with bash
scripst(post_translate it, but I receive some errors, like;
Exception occurred:
File "/usr/lib/python2.7/dist-packages/sphinx/builders/html.py", line
419, in write_doc
self.docwriter.write(doctree, destination)
File "/usr/lib/python2.7/dist-packages/docutils/writers/__init__.py",
line 77, in write
self.translate()
File "/usr/lib/python2.7/dist-packages/sphinx/writers/html.py", line
38, in translate
self.document.walkabout(visitor)
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 173,
in walkabout
if child.walkabout(visitor):
in walkabout
in walkabout
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 165,
in walkabout
visitor.dispatch_visit(self)
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 1604,
in dispatch_visit
return method(node)
File
"/usr/lib/python2.7/dist-packages/docutils/writers/html4css1/__init__.py",
line 957, in visit_footnote_reference
href = '#' + node['refid']
File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 534,
in __getitem__
return self.attributes[key]
KeyError: 'refid'
What does it mean? Actually not for all the files I found the html. For
example the entire folder working with vectors does not compare in the
output.
I attach the output lof file.
Thanks
Matteo
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130517/b1259d53/attachment.bin>
More information about the Qgis-community-team
