[Qgis-community-team] [Qgis-user] update QGIS user manual - contributors
Otto Dassau
dassau at gbd-consult.de
Wed May 15 09:27:52 PDT 2013
thanks Jean Roc! I added all notes to the documentation_guidelines/README.rst
https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/documentation_guidelines/README.rst
Alexandre, if you are already familiar with github it is perfect! And no,
there is no prefered style, Gnome would be fine.
The data used for the screemshots are in
QGIS-Documentation/resources/en/user_manual/
Looking forward to your first pull request :)
Regards
Otto
Am Wed, 15 May 2013 16:54:53 +0100
schrieb Alexandre Neto <senhor.neto at gmail.com>:
> Hello again,
> From time to time, I help with the Portuguese translation of the GUI, so if
> the docs are in some repository (like github) I can just create new version
> one by one in a my local repository and then do a pull request.
> I can start right now, but I can't give any certain about the time I will
> need to finish it.
> I already have qgis master installed but I might need to update it.
> I think I wont have problems following the recommendations for creating the
> screenshots. But I will send you some first screenshots to make sure
> everything is well.
> Is there any preference for the style used?
> I use ubuntu 12.04 as my home primary operating system, that means that
> things might not look exactly as the current screenshots (for instance
> global menus). Can that be a problem?
> I will also need to know where the data used for the screenshots is.
> Best regards,
> Alexandre Neto
> On Wed, May 15, 2013 at 4:35 PM, MORREALE Jean Roc
> <jr.morreale at enoreth.net>wrote:
> > My how-to :
> > - same environnement for all the screen caps (same OS, same decoration,
> > same font size)
> > - reduce the window to the minimal space needed to show the feature
> > (taking the all screen for a small modal window > overkill)
> > - the less clutter, the better (no need to activate all the toolbars)
> > - don't resize them in an image editor, the size will be set into the rst
> > files (downscalling th dimensions without properly upping the resolution
> > > ugly)
> > - cut the background
> > - save them in png (no jpeg artefacts)
> > Le 15/05/2013 17:21, Otto Dassau a écrit :
> > Hi Alexandre,
> >> ok, maybe the easiest way would be, if I send you the folder with all
> >> english screenshots. Then you update and send them all back to me. Just
> >> tell
> >> me, when you want to start. Do you have a current QGIS master version
> >> installed?
> >> The zip file with the screenshots is about 12MB.
> >> Please note, it is important, that, if possible:
> >> * the new screenshots should show the same content or similar, according
> >> to
> >> what they shall show
> >> * the new screenshots should have the same size as the older one. This
> >> would
> >> make it easier for us to integrate it in the existing structure.
> >> * the screenshot format is PNG
> >> * try to keep the size small but the screenshot still sharp :)
> >> Would that be ok for you?
> >> Regards
> >> Otto
More information about the Qgis-community-team
