[Qgis-community-team] [Qgis-user] update QGIS user manual - contributors
Alexandre Neto
senhor.neto at gmail.com
Wed May 15 08:54:53 PDT 2013
Hello again,
>From time to time, I help with the Portuguese translation of the GUI, so if
the docs are in some repository (like github) I can just create new version
one by one in a my local repository and then do a pull request.
I can start right now, but I can't give any certain about the time I will
need to finish it.
I already have qgis master installed but I might need to update it.
I think I wont have problems following the recommendations for creating the
screenshots. But I will send you some first screenshots to make sure
everything is well.
Is there any preference for the style used?
I use ubuntu 12.04 as my home primary operating system, that means that
things might not look exactly as the current screenshots (for instance
global menus). Can that be a problem?
I will also need to know where the data used for the screenshots is.
Best regards,
Alexandre Neto
On Wed, May 15, 2013 at 4:35 PM, MORREALE Jean Roc
<jr.morreale at enoreth.net>wrote:
> My how-to :
> - same environnement for all the screen caps (same OS, same decoration,
> same font size)
> - reduce the window to the minimal space needed to show the feature
> (taking the all screen for a small modal window > overkill)
> - the less clutter, the better (no need to activate all the toolbars)
> - don't resize them in an image editor, the size will be set into the rst
> files (downscalling th dimensions without properly upping the resolution >
> ugly)
> - cut the background
> - save them in png (no jpeg artefacts)
> Le 15/05/2013 17:21, Otto Dassau a écrit :
> Hi Alexandre,
>> ok, maybe the easiest way would be, if I send you the folder with all
>> english screenshots. Then you update and send them all back to me. Just
>> tell
>> me, when you want to start. Do you have a current QGIS master version
>> installed?
>> The zip file with the screenshots is about 12MB.
>> Please note, it is important, that, if possible:
>> * the new screenshots should show the same content or similar, according
>> to
>> what they shall show
>> * the new screenshots should have the same size as the older one. This
>> would
>> make it easier for us to integrate it in the existing structure.
>> * the screenshot format is PNG
>> * try to keep the size small but the screenshot still sharp :)
>> Would that be ok for you?
>> Regards
>> Otto
> ______________________________**_________________
> Qgis-community-team mailing list
> Qgis-community-team at lists.**osgeo.org<Qgis-community-team at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/qgis-**community-team<http://lists.osgeo.org/mailman/listinfo/qgis-community-team>
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130515/b9ed7e26/attachment.html>
More information about the Qgis-community-team
