[Qgis-community-team] [Qgis-user] update QGIS user manual - contributors
MORREALE Jean Roc
jr.morreale at enoreth.net
Wed May 15 08:35:36 PDT 2013
My how-to :
- same environnement for all the screen caps (same OS, same decoration,
same font size)
- reduce the window to the minimal space needed to show the feature
(taking the all screen for a small modal window > overkill)
- the less clutter, the better (no need to activate all the toolbars)
- don't resize them in an image editor, the size will be set into the
rst files (downscalling th dimensions without properly upping the
resolution > ugly)
- cut the background
- save them in png (no jpeg artefacts)
Le 15/05/2013 17:21, Otto Dassau a écrit :
> Hi Alexandre,
> ok, maybe the easiest way would be, if I send you the folder with all
> english screenshots. Then you update and send them all back to me. Just tell
> me, when you want to start. Do you have a current QGIS master version
> installed?
> The zip file with the screenshots is about 12MB.
> Please note, it is important, that, if possible:
> * the new screenshots should show the same content or similar, according to
> what they shall show
> * the new screenshots should have the same size as the older one. This would
> make it easier for us to integrate it in the existing structure.
> * the screenshot format is PNG
> * try to keep the size small but the screenshot still sharp :)
> Would that be ok for you?
> Regards
> Otto
More information about the Qgis-community-team
