[Qgis-community-team] sphinx trouble
matteo
matteo.ghetta at gmail.com
Tue May 21 08:16:20 PDT 2013
Il 21/05/2013 16:39, Otto Dassau ha scritto:
> Hi Matteo,
> these are warnings. Usually strings or punctuation marks are different
> between the original (english) and the translation (italian). You should
> check for that.
> but more important is to fix the errors...
Ok, but what about this error?
/home/matteo/Documenti/qgis_translation/QGIS-Documentation/source/docs/user_manual/working_with_vector/editing_geometry_attributes.rst:13:
ERROR: Error in "note" directive:
invalid option block.
.. note::
The procedure for editing GRASS layers is different - see Section
:ref:`grass_digitizing` for details.
I controlled the po file and the string :ref:`grass_digitizing` isn't there.
So I launched the pre_translate script, I checked again the po file and
the string :ref:`grass_digitizing` doesn't appear.
The post_translate script stops to write the outputs with the working
with raster folder (but not all the file inside the folders are
compiled, e.g. in the raster folder only 3 files are added (index,
calculator and properties).
Matteo
More information about the Qgis-community-team
