[Qgis-community-team] sphinx trouble
Otto Dassau
dassau at gbd-consult.de
Tue May 21 07:39:29 PDT 2013
Hi Matteo,
these are warnings. Usually strings or punctuation marks are different
between the original (english) and the translation (italian). You should
check for that.
but more important is to fix the errors...
Regards
Otto
Am Tue, 21 May 2013 16:09:52 +0200
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi,
> I fixed some errors in the .po files, but I cannot understand what I
> should do when the terminal writes for example:
> /home/matteo/Documenti/qgis_translation/QGIS-Documentation/source/docs/user_manual/working_with_vector/editing_geometry_attributes.rst:1:
> WARNING: Inline interpreted text or phrase reference start-string
> without end-string.
> or
> /home/matteo/Documenti/qgis_translation/QGIS-Documentation/source/docs/user_manual/introduction/getting_started.rst:2:
> WARNING: Literal block expected; none found.
> The po files now are ready and corrected.
> In line 1 of the rst file I don't see anything wrong, so don't know what
> to do.
> Cheers,
> Matteo
More information about the Qgis-community-team
