[Qgis-community-team] user manual 2.0 good news
Otto Dassau dassau at gbd-consult.de
Mon Nov 4 02:06:55 PST 2013
yes it works. I added it to conf.py and I use make html / make pdf with a
virtualenv.
Regards
Otto
Am Fri, 1 Nov 2013 14:08:44 +0000
schrieb Alexandre Neto <senhor.neto at gmail.com>:
> Hello,
> Otto, did the :width: 1.3em worked? I have tried several times and with no
> success. I was using the pos_translate.sh.
> Regards,
> Alexandre
> On Fri, Nov 1, 2013 at 9:33 AM, Richard Duivenvoorde
> <richard at duif.net>wrote:
> > On 01-11-13 08:54, Otto Dassau wrote:
> > > Hi Alexandre,
> > > I also went through the pdf again, fixed some links, shortened lines to
> > fit
> > > on the page and defined the checkbox size.
> > > Thanks for taking care about the figure size and I agree that we should
> > focus
> > > on the pdf.
> > If you make changes and want to know how it currently looks, give me a
> > call, and I will start the build for you
> > Regards,
> > Richard
More information about the Qgis-community-team mailing list
