[Qgis-community-team] user manual 2.0 good news
Alexandre Neto senhor.neto at gmail.com
Mon Nov 4 08:01:05 PST 2013
No dia 4 de Nov de 2013 10:07, "Otto Dassau" <dassau at gbd-consult.de>
escreveu:
> Hi,
> yes it works. I added it to conf.py and I use make html / make pdf with a
> virtualenv.
thats probably my problem. I am seeing that my changes to conf.py did not
aply to my make pdf. how can i set the virtual enviorment?
thanks!
> Regards
> Otto
> Am Fri, 1 Nov 2013 14:08:44 +0000
> schrieb Alexandre Neto <senhor.neto at gmail.com>:
> > Hello,
> > Otto, did the :width: 1.3em worked? I have tried several times and with
no
> > success. I was using the pos_translate.sh.
> > Regards,
> > Alexandre
> > On Fri, Nov 1, 2013 at 9:33 AM, Richard Duivenvoorde
> > <richard at duif.net>wrote:
> > > On 01-11-13 08:54, Otto Dassau wrote:
> > > > Hi Alexandre,
> > > > I also went through the pdf again, fixed some links, shortened
lines to
> > > fit
> > > > on the page and defined the checkbox size.
> > > > Thanks for taking care about the figure size and I agree that we
should
> > > focus
> > > > on the pdf.
> > > If you make changes and want to know how it currently looks, give me a
> > > call, and I will start the build for you
> > > Regards,
> > > Richard
> Qgis-community-team mailing list for organizing community resources such
as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20131104/88cb59a8/attachment.html>
More information about the Qgis-community-team mailing list
