[Qgis-community-team] user manual 2.0 good news
Otto Dassau
dassau at gbd-consult.de
Tue Nov 5 07:57:39 PST 2013
Hi Richard,
I adapted image size again and the pdf and html look ok to me. The problem
is not solved yet, how to automatically optimize figure size and resolution
for html and pdf build. But to whom should we wait to solve this?
I don't think we should stop translation any longer, now that the content
is up-to-date.
Regards
Otto
Am Tue, 05 Nov 2013 16:48:43 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 05-11-13 12:16, Otto Dassau wrote:
> > what about "releasing" the current manual as QGIS 2.0 and branch for
> > translation? I think we should not wait any longer. I fixed/changed some
> > more things / figure sizes for the pdf and I think it looks ok.
> > We could try to improve the figures for the next version.
> > What do yo think? Richard, would it be ok for you to create translation
> > branch for 2.0 and prepare it for transifex, etc?
> Hi Otto,
> sure fine, but is all work on images in pdf and html now ok?
> I just did 'make world' on the server, so within some time this url
> http://docs.qgis.org/testing/
> should show you current status. (by the way:
> http://docs.qgis.org/2.0 is currently pointing to exact the same place,
> but will be updated after branch to point to a 2.0 build of the docs)
> This url:
> http://docs.qgis.org/testing/pdf/
> should contain pdf's dated on the 5th of November.
> Please check if these are all ok.
> If OK, we could branch 2.0,
> I'll run 'make pretranslate' on it, which will generate pot/english po
> files which then can be pushed to Transifex.
> At that moment the Transifex documentation project wil NOT be the
> translations of master anymore, but the translation of 2.0
> To be sure nobody we can remove all .po files (translations) from master
> branch, but that means that even current translations will NOT be visible.
> So
> at http://docs.qgis.org/testing/
> will only be available in english...
> Not sure if that is what we want though..
> Regards,
> Richard
More information about the Qgis-community-team
