[Qgis-community-team] API documentation and a missing link
Richard Duivenvoorde rdmailings at duif.net
Tue Nov 5 22:59:55 PST 2013
On 03-11-13 21:47, Borys Jurgiel wrote:
> Hi,
> At http://www.qgis.org/api you can see the Master's API and links to some
> earlier 1.x API versions. However, the most important link to
> http://www.qgis.org/api/2.0 is missing.
> It may confuse plugin devs and make them writting 2.0 plugins not fully
> compatible with the stable API. What about two big buttons: Stable | Master?
> If I remember correctly, they were present in the 1.8 times and it was working
> well.
Hi Borys,
I did a little search in codebase where this should be, and found this one:
https://github.com/qgis/QGIS/blob/master/doc/index.dox
apparently Jurgen already updated this template (in master).
I've found a script in a cron job (Otto's?) on qgis server:
/usr/local/sbin/update-api-doc
which does 'something' with debian packages, but I'm not sure why it is
not build yet.
And/or how to fix those links in the older builds..
Regards,
Richard
More information about the Qgis-community-team mailing list
