[Qgis-community-team] error building docs locally
    Otto Dassau
    dassau at gbd-consult.de
    Tue Oct  8 02:29:19 PDT 2013
yes, easy :) - thanks!
Otto
Am Tue, 8 Oct 2013 11:19:52 +0200
schrieb Werner Macho <werner.macho at gmail.com>:
> hi otto
> just to be sure
> pip install sphinx_bootstrap_theme
> probably it is not installed?
> On Tue, Oct 8, 2013 at 11:17 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
> > Hi Richard,
> > if I want to build the docs locally I get following error (both using
> > scripts-old and make html):
> > ImportError: No module named sphinx_bootstrap_theme
> > make: *** [html] Fehler 1
> > Can you help, how to fix this?
> > Thanks
> > Otto
More information about the Qgis-community-team
