[Qgis-community-team] manual in pdf
Richard Duivenvoorde
richard at duif.net
Sat Oct 12 11:03:08 PDT 2013
On 12-10-13 11:09, NUIMURA, Takayuki wrote:
> In Japanese LaTeX community, it is known that, pdftex (pdflatex) cause
> error for compilation with Japanese font.
> Hence, we Japanese use platex + dvipdfmx command as alternative of pdftex.
> And platex command cannot read png image format. A bounding box file
> (*.bb) must be generate before compilation.
we are not using the post_translate.sh anymore, but the Makefile:
https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L101
as you see I changed it to reflect your changes, and indeed on my laptop
(Debian testing) locally I can generate both russian and japanese with
platex, after I installed-lang-cjk
sudo apt-get install texlive-lang-cjk
and instructed ebb to generate bbx files (via -x)
But on qgis-server we run squeeze, and this package is not available.
There only ptex provides platex.
But I cannot get platex get to generate pdf there. It stops with some of
these errors:
Package inputenc Error: Unicode char \u8:�^^80^^8b not set up for use
with La
TeX.
LaTeX Font Warning: Font shape `JY1/gt/bx/it' undefined
(Font) using `JY1/gt/bx/n' instead on input line 120.
! Package inputenc Error: Unicode char \u8:リ� not set up for use with
LaTeX.
See the inputenc package documentation for explanation.
Type H <return> for immediate help.
l.120 \tableofcontents
I tried to install japanese fonts, but that did not help. Google seems
to think my latex is just too old???
I uploaded the ja and ru generated on my laptop ere:
http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ja.pdf
http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ru.pdf
Are these ok?
Please let me know if somebody can help me to fix the generation of
pdf's on the qgis server.
Regards,
More information about the Qgis-community-team
