[Qgis-community-team] manual in pdf
Werner Macho
werner.macho at gmail.com
Sat Oct 12 11:30:56 PDT 2013
Hi Richard!
What about setting up a docker instance with the newest debian available
(or whatever we need to build the documentation)?
In that way we would have a dedicated instance to build it and could
copy the pdf and Documentation to the correct path ...
Do you think this will be possible?
regards
Werner
On 10/12/2013 08:03 PM, Richard Duivenvoorde wrote:
> On 12-10-13 11:09, NUIMURA, Takayuki wrote:
>> In Japanese LaTeX community, it is known that, pdftex (pdflatex) cause
>> error for compilation with Japanese font.
>> Hence, we Japanese use platex + dvipdfmx command as alternative of pdftex.
>> And platex command cannot read png image format. A bounding box file
>> (*.bb) must be generate before compilation.
> Hi,
> we are not using the post_translate.sh anymore, but the Makefile:
> https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L101
> as you see I changed it to reflect your changes, and indeed on my laptop
> (Debian testing) locally I can generate both russian and japanese with
> platex, after I installed-lang-cjk
> sudo apt-get install texlive-lang-cjk
> and instructed ebb to generate bbx files (via -x)
> But on qgis-server we run squeeze, and this package is not available.
> There only ptex provides platex.
> But I cannot get platex get to generate pdf there. It stops with some of
> these errors:
> Package inputenc Error: Unicode char \u8:�^^80^^8b not set up for use
> with La
> TeX.
> LaTeX Font Warning: Font shape `JY1/gt/bx/it' undefined
> (Font) using `JY1/gt/bx/n' instead on input line 120.
> ! Package inputenc Error: Unicode char \u8:リ� not set up for use with
> LaTeX.
> See the inputenc package documentation for explanation.
> Type H <return> for immediate help.
> l.120 \tableofcontents
> I tried to install japanese fonts, but that did not help. Google seems
> to think my latex is just too old???
> I uploaded the ja and ru generated on my laptop ere:
> http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ja.pdf
> http://docs.qgis.org/testing/pdf/QGIS-testing-UserGuide-ru.pdf
> Are these ok?
> Please let me know if somebody can help me to fix the generation of
> pdf's on the qgis server.
> Regards,
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
