[Qgis-community-team] manual in pdf
Richard Duivenvoorde rdmailings at duif.net
Mon Oct 14 21:37:51 PDT 2013
On 15-10-13 05:23, NUIMURA, Takayuki wrote:
> Could you update Makefile?
Thanks!
Yep, I will update the Makefile. I will also try to find something like
"texlive-lang-cyrillic" for japanese (which was needed for russian for
us westerlings).
But still the problem remains on Debian Wheezy. Are you aware of a way
to produce valid pdf's on there? Because that is the current OS of the
server where all docs are build. I have troubles using platex there...
Another workaround would be to (let it) build somewhere else, and upload
it regularly to docs.qgis.org
Thanks for you help,
Richard
More information about the Qgis-community-team mailing list
