[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Richard Duivenvoorde
richard at duif.net
Mon Jun 16 23:15:12 PDT 2014
Thanks fro you answer,
I tried to add texlive-lang-cjk (which adds texlive-lang-ko) and tried
both options we use to build a pdf from a tex file.
See
https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L102-L114 for
the two options we use.
The texi2pdf way quits immediately, the platex way finishes with some
errors, but there are no korean characters in the generated pdf.
For khmer I can not find a reference to some lang file.
I hope somebody from khmer of korean community can invest some time in
this to investigate.
Regards,
On 16-06-14 15:41, BJ Jang wrote:
> Hi Richard.
> According to the information I have found, for Korean, miktex is not
> work but texlive can make PDF.
> Cause is that texlive included Ko,TeX file basically.
> Regards,
> BJ Jang
> 2014-06-15 22:59 GMT+09:00 Richard Duivenvoorde <richard at duif.net
> <mailto:richard at duif.net>>:
> Hi Lists,
> as you maybe know we build pdf versions of different documentation
> objects:
> http://docs.qgis.org/2.2/pdf/
> as you can see there, all languages EXCEPT korean and hindi are build.
> We already have a switch because japanese pdf needed another way of
> building pdf's, see
> So Question:
> is somebody able to build the Korean and or Hindi version of the docs
> (pereferably on Debian as that is our build platform)?
> If so, can you please let us know what we miss (like certain fonts or
> tools or libs).
> If not: is somebody available with more latex knowledge then me who can
> create pdf's from the created tex files? Creation of html is ok, as is
> the creation of tex files. It is just the last step that is (silently)
> failing.
> Help is much appreciated.
> Regards,
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
> Open Source GIS Technical Manager / e-Cartographer
> BJ Jang**
> *Gaia3D Inc,*
More information about the Qgis-community-team
