[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
    Ko Nagase
    nagase at georepublic.co.jp
    Tue Jun 17 03:01:03 PDT 2014
Hi Richards, BJ Jang
"platex" is for only Japanese,
so please use "xelatex" to process other languages as follows.
[Additional packages for Ubuntu 12.04 (precise) ... nearly equal Debian Squeeze]
cmap-adobe-korea1
fonts-nanum
fonts-nanum-coding
fonts-nanum-extra
fonts-unfonts-core
(Probably, the followings will be necessary for Hindi)
ttf-devanagari-fonts
ttf-indic-fonts
texlive-lang-indic
latex-sanskrit
[Makefile modification part]
@-if [ $(LANG) = "ko" -o $(LANG) = "hi" ]; then \
    cp -f $(SOURCEDIR)/conf.py $(SOURCEDIR)/i18n/$(LANG)/; \
    cat $(SOURCEDIR)/i18n/$(LANG)/conf.py.diff >>
$(SOURCEDIR)/i18n/$(LANG)/conf.py; \
    $(SPHINXBUILD) -b latex -c $(SOURCEDIR)/i18n/$(LANG)
$(ALLSPHINXOPTS) $(BUILDDIR)/latex/$(LANG); \
else \
    $(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex/$(LANG); \
fi
elif [ $(LANG) = "ko" -o $(LANG) = "hi" ]; then \
    cd $(BUILDDIR)/latex/$(LANG); \
    xelatex -interaction=batchmode --no-pdf -shell-escape QGISUserGuide.tex; \
    xdvipdfmx QGISUserGuide.xdv; \
else \
## Other manuals are same as above.
[Create "source/i18n/ko/conf.py.diff" with the following contents]
latex_elements = {
    'inputenc': '',
    'utf8extra': '',
    'preamble': '''
\usepackage{fontspec}
\usepackage{xeCJK}
\setCJKmainfont{NanumMyeongjo}
To create Hindi PDF, other "source/i18n/hi/conf.py.diff" will be necessary,
but I don't know how to set "latex_elements" parameters for Hindi.
Result Korean PDF file is here.
Ubuntu 12.04 (precise):
https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-precise.pdf
> BJ Jang
I am not sure whether above PDF is valid one,
so could you check this ?
Thanks,
2014-06-17 15:15 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
> Thanks fro you answer,
> I tried to add texlive-lang-cjk (which adds texlive-lang-ko) and tried
> both options we use to build a pdf from a tex file.
> See
> https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L102-L114 for
> the two options we use.
> The texi2pdf way quits immediately, the platex way finishes with some
> errors, but there are no korean characters in the generated pdf.
> For khmer I can not find a reference to some lang file.
> I hope somebody from khmer of korean community can invest some time in
> this to investigate.
> Regards,
> On 16-06-14 15:41, BJ Jang wrote:
>> Hi Richard.
>> According to the information I have found, for Korean, miktex is not
>> work but texlive can make PDF.
>> Cause is that texlive included Ko,TeX file basically.
>> Regards,
>> BJ Jang
>> 2014-06-15 22:59 GMT+09:00 Richard Duivenvoorde <richard at duif.net
>> <mailto:richard at duif.net>>:
>>     Hi Lists,
>>     as you maybe know we build pdf versions of different documentation
>>     objects:
>>     http://docs.qgis.org/2.2/pdf/
>>     as you can see there, all languages EXCEPT korean and hindi are build.
>>     We already have a switch because japanese pdf needed another way of
>>     building pdf's, see
>>     So Question:
>>     is somebody able to build the Korean and or Hindi version of the docs
>>     (pereferably on Debian as that is our build platform)?
>>     If so, can you please let us know what we miss (like certain fonts or
>>     tools or libs).
>>     If not: is somebody available with more latex knowledge then me who can
>>     create pdf's from the created tex files? Creation of html is ok, as is
>>     the creation of tex files. It is just the last step that is (silently)
>>     failing.
>>     Help is much appreciated.
>>     Regards,
>>     _______________________________________________
>>     Qgis-tr mailing list
>>     Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/qgis-tr
>> Open Source GIS Technical Manager / e-Cartographer
>> BJ Jang**
>> *Gaia3D Inc,*
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase at georepublic.co.jp
web: http://georepublic.co.jp
More information about the Qgis-community-team
