[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Richard Duivenvoorde richard at duif.net
Tue Jun 17 05:14:48 PDT 2014
On 17-06-14 12:01, Ko Nagase wrote:
Ah, thanks for this!
I had to install some more stuff (he, this is a western laptop :-)):
texlive-xetex ko.tex-base ko.tex-extra
BUT and forgot to do this:
> [Create "source/i18n/ko/conf.py.diff" with the following contents]
> latex_elements = {
>     'inputenc': '',
>     'utf8extra': '',
>     'preamble': '''
> \usepackage{fontspec}
> \usepackage{xeCJK}
> \setCJKmainfont{NanumMyeongjo}
Then I got (locally here on my laptop):
http://docs.qgis.org/2.2/pdf/ko/QGIS-2.2-UserGuide-ko.pdf
which in de index shows me Korean chars, but in the actual manual text NOT.
Can you elaborate a little more about  source/i18n/ko/conf.py.diff ?
is this supposed to be a diff file, so I have to patch the conf.py
during korean runs?
Or is it supposed to be a diff file which will be picked up by the latex
machinery somewhere?
Thanks for any info,
More information about the Qgis-community-team mailing list
