[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
    Ko Nagase
    nagase at georepublic.co.jp
    Tue Jun 17 05:32:52 PDT 2014
Hi BJ Jang,
Thanks for your confirmation.
2014-06-17 19:44 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
> But it have one important problem, all SPACE CHAR in Korean string is
> removed like Japanese string.
> In korean, space char is important like English.
Okay, I confirmed the space char on html output.
After googling, I found some sites([1], [2]),
but [1] didn't fix this issue.
([2] seems to mention that it is xelatex bug.)
[1] http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
[2] http://qandasys.info/spacing-only-works-in-xecjk-for-chinese-and-japanses-but-not-korean/#comments
If you find how to fix this issue by setting xelatex configuration,
then please tell me.
Thanks,
> Do you have some idea for solve it?
> 2014-06-17 19:01 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> Hi Richards, BJ Jang
>> "platex" is for only Japanese,
>> so please use "xelatex" to process other languages as follows.
>> [Additional packages for Ubuntu 12.04 (precise) ... nearly equal Debian
>> Squeeze]
>> cmap-adobe-korea1
>> fonts-nanum
>> fonts-nanum-coding
>> fonts-nanum-extra
>> fonts-unfonts-core
>> (Probably, the followings will be necessary for Hindi)
>> ttf-devanagari-fonts
>> ttf-indic-fonts
>> texlive-lang-indic
>> latex-sanskrit
>> [Makefile modification part]
>> @-if [ $(LANG) = "ko" -o $(LANG) = "hi" ]; then \
>>     cp -f $(SOURCEDIR)/conf.py $(SOURCEDIR)/i18n/$(LANG)/; \
>>     cat $(SOURCEDIR)/i18n/$(LANG)/conf.py.diff >>
>> $(SOURCEDIR)/i18n/$(LANG)/conf.py; \
>>     $(SPHINXBUILD) -b latex -c $(SOURCEDIR)/i18n/$(LANG)
>> $(ALLSPHINXOPTS) $(BUILDDIR)/latex/$(LANG); \
>> else \
>>     $(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex/$(LANG); \
>> fi
>> elif [ $(LANG) = "ko" -o $(LANG) = "hi" ]; then \
>>     cd $(BUILDDIR)/latex/$(LANG); \
>>     xelatex -interaction=batchmode --no-pdf -shell-escape
>> QGISUserGuide.tex; \
>>     xdvipdfmx QGISUserGuide.xdv; \
>> else \
>> ## Other manuals are same as above.
>> [Create "source/i18n/ko/conf.py.diff" with the following contents]
>> latex_elements = {
>>     'inputenc': '',
>>     'utf8extra': '',
>>     'preamble': '''
>> \usepackage{fontspec}
>> \usepackage{xeCJK}
>> \setCJKmainfont{NanumMyeongjo}
>> To create Hindi PDF, other "source/i18n/hi/conf.py.diff" will be
>> necessary,
>> but I don't know how to set "latex_elements" parameters for Hindi.
>> Result Korean PDF file is here.
>> Ubuntu 12.04 (precise):
>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-precise.pdf
>> > BJ Jang
>> I am not sure whether above PDF is valid one,
>> so could you check this ?
>> Thanks,
>> 2014-06-17 15:15 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>> > Thanks fro you answer,
>> > I tried to add texlive-lang-cjk (which adds texlive-lang-ko) and tried
>> > both options we use to build a pdf from a tex file.
>> > See
>> > https://github.com/qgis/QGIS-Documentation/blob/master/Makefile#L102-L114
>> > for
>> > the two options we use.
>> > The texi2pdf way quits immediately, the platex way finishes with some
>> > errors, but there are no korean characters in the generated pdf.
>> > For khmer I can not find a reference to some lang file.
>> > I hope somebody from khmer of korean community can invest some time in
>> > this to investigate.
>> > Regards,
>> > On 16-06-14 15:41, BJ Jang wrote:
>> >> Hi Richard.
>> >> According to the information I have found, for Korean, miktex is not
>> >> work but texlive can make PDF.
>> >> Cause is that texlive included Ko,TeX file basically.
>> >> Regards,
>> >> BJ Jang
>> >> 2014-06-15 22:59 GMT+09:00 Richard Duivenvoorde <richard at duif.net
>> >> <mailto:richard at duif.net>>:
>> >>     Hi Lists,
>> >>     as you maybe know we build pdf versions of different documentation
>> >>     objects:
>> >>     http://docs.qgis.org/2.2/pdf/
>> >>     as you can see there, all languages EXCEPT korean and hindi are
>> >> build.
>> >>     We already have a switch because japanese pdf needed another way of
>> >>     building pdf's, see
>> >>     So Question:
>> >>     is somebody able to build the Korean and or Hindi version of the
>> >> docs
>> >>     (pereferably on Debian as that is our build platform)?
>> >>     If so, can you please let us know what we miss (like certain fonts
>> >> or
>> >>     tools or libs).
>> >>     If not: is somebody available with more latex knowledge then me who
>> >> can
>> >>     create pdf's from the created tex files? Creation of html is ok, as
>> >> is
>> >>     the creation of tex files. It is just the last step that is
>> >> (silently)
>> >>     failing.
>> >>     Help is much appreciated.
>> >>     Regards,
>> >>     _______________________________________________
>> >>     Qgis-tr mailing list
>> >>     Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>> >>     http://lists.osgeo.org/mailman/listinfo/qgis-tr
>> >> Open Source GIS Technical Manager / e-Cartographer
>> >> BJ Jang**
>> >> *Gaia3D Inc,*
>> > Qgis-community-team mailing list for organizing community resources such
>> > as documentation, translation etc..
>> > Qgis-community-team at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>> Ko Nagase (長瀬 興)
>> Georepublic Japan
>> mail: nagase at georepublic.co.jp
>> web: http://georepublic.co.jp
> BJ Jang
> Gaia3D Inc,
Ko Nagase (長瀬 興)
Georepublic Japan
More information about the Qgis-community-team
