[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Ko Nagase
nagase at georepublic.co.jp
Sat Jun 21 00:55:41 PDT 2014
Hi BJ Jang,
Okay!
Thanks for your confirmation.
Regards,
Ko
2014-06-21 16:09 GMT+09:00 BJ Jang <qgis.tr.kr at gmail.com>:
> Dear Ko
> Thank you so much!!!
> We got a perfect Korean pdf translation.
> All about formatting(Font, spacing, images) is good!
> Thank you again Ko.
> Regards
> BJ Jang
> 2014-06-20 21:23 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> Hi BJ Jang, Hindi translator, Richard
>> > BJ Jang
>> I fixed Korean space issue by using Debian Wheezy newer xeCJK module,
>> and applying the following link way.
>> 2014-06-17 21:32 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> > [1]
>> > http://tex.stackexchange.com/questions/17292/how-to-write-spaces-between-korean-words-with-xecjk/
>> So, could you check the following new PDF again?
>> Korean PDF:
>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-ko-wheezy.pdf
>> > Hindi translator
>> I added Hindi version PDF here.
>> Hindi PDF:
>> https://dl.dropboxusercontent.com/u/93823511/QGIS-testing-UserGuide-hi-wheezy.pdf
>> I hope that someone check this one.
>> > Richard
>> I updated my "xelatex" branch to fix Korean space issue and add Hindi
>> extra settings.
>> If above files are valid ones, I will create pull request.
>> == [xelatex] ==
>> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
>> I also created "vagrant" branch to use Debian Wheezy 7.5 x64 image on
>> my MacOSX note PC.
>> About package lists for the image, please see the following
>> "bootstrap.sh".
>> == [vagrant] ==
>> branch root: https://github.com/sanak/QGIS-Documentation/tree/vagrant
>> bootstrap.sh:
>> https://github.com/sanak/QGIS-Documentation/blob/vagrant/vagrant/wheezy64/bootstrap.sh
>> I wrote that I will try also Debian Squeeze environement in this weekend,
>> but I become busy with other tasks, so I set this status to pending for a
>> while.
>> Regards,
>> Ko
>> 2014-06-18 21:16 GMT+09:00 Ko Nagase <nagase at georepublic.co.jp>:
>> > Hi Richard, BJ Jang
>> > Thanks for confirmation.
>> > I just pushed yesterday code to my git repository "xelatex" branch.
>> > commit diff:
>> > https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
>> > I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
>> > too old (Version 2.3.10 (30-Sept-2009)),
>> > and that seems to be the cause of Korean space issue.
>> > It may also be possible to build xeCJK source by hand,
>> > but I am not so familiar with LaTeX .etc...
>> > Is there some plan about upgrading current documentation server to
>> > Debian Wheezy?
>> > Anyway, I will try to create Debian Squeeze/Wheezy environment from
>> > scratch by Vagrant,
>> > and check it again in this weekend, because now I am testing only on
>> > Ubuntu 12.04 (precise).
>> > Thanks,
>> > 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>> >> On 17-06-14 14:50, Ko Nagase wrote:
>> >>> So, please check that your current "source/i18n/ko/conf.py" includes
>> >>> both original "source/conf.py"
>> >>> and extra "source/i18n/ko/conf.py.diff" contents.
>> >> Thanks for the hints.
>> >> I added this piece of config in the normal source.conf file, but do not
>> >> get better results then the other pdf without.
>> >> It is not clear to me if this is because of my own setup (missing
>> >> essential korean fonts or packages) or if I'm doing something else
>> >> wrong.
>> >> BJ Jang: are you able to build the Korean pdf yourself?
>> >> Any help is appreciated
>> >> Regards,
>> > Ko Nagase (長瀬 興)
>> > Georepublic Japan
>> > mail: nagase at georepublic.co.jp
>> > web: http://georepublic.co.jp
>> Ko Nagase (長瀬 興)
>> Georepublic Japan
> Open Source GIS Technical Manager / e-Cartographer
> BJ Jang
> Gaia3D Inc,
Ko Nagase (長瀬 興)
Georepublic Japan
More information about the Qgis-community-team
