[Qgis-community-team] [Qgis-tr] latex/pdf guru's for failing Korean and Hindi pdf build available?
Richard Duivenvoorde richard at duif.net
Wed Jun 18 05:27:23 PDT 2014
Hi Ko Nagase,
myself I tested on my Debian jessie/testing laptop here.
the machine used for building is a Docker image based on wheezy.
I'll try there and see how it looks.
Regards,
Richard
On 18-06-14 14:16, Ko Nagase wrote:
> Hi Richard, BJ Jang
> Thanks for confirmation.
> I just pushed yesterday code to my git repository "xelatex" branch.
> branch root: https://github.com/sanak/QGIS-Documentation/tree/xelatex
> commit diff: https://github.com/sanak/QGIS-Documentation/commit/e9a02494547c5b8f7ed4581c57ee492cd9b4ecff
> I confirmed Ubuntu 12.04 (precise = Debian Squeeze) xeCJK package is
> too old (Version 2.3.10 (30-Sept-2009)),
> and that seems to be the cause of Korean space issue.
> It may also be possible to build xeCJK source by hand,
> but I am not so familiar with LaTeX .etc...
> Is there some plan about upgrading current documentation server to
> Debian Wheezy?
> Anyway, I will try to create Debian Squeeze/Wheezy environment from
> scratch by Vagrant,
> and check it again in this weekend, because now I am testing only on
> Ubuntu 12.04 (precise).
> Thanks,
> 2014-06-18 20:21 GMT+09:00 Richard Duivenvoorde <richard at duif.net>:
>> On 17-06-14 14:50, Ko Nagase wrote:
>>> So, please check that your current "source/i18n/ko/conf.py" includes
>>> both original "source/conf.py"
>>> and extra "source/i18n/ko/conf.py.diff" contents.
>> Thanks for the hints.
>> I added this piece of config in the normal source.conf file, but do not
>> get better results then the other pdf without.
>> It is not clear to me if this is because of my own setup (missing
>> essential korean fonts or packages) or if I'm doing something else wrong.
>> BJ Jang: are you able to build the Korean pdf yourself?
>> Any help is appreciated
>> Regards,
More information about the Qgis-community-team mailing list
