[Qgis-community-team] .po files in documentation master branch
Alexander Bruy
alexander.bruy at gmail.com
Fri Mar 28 05:56:08 PDT 2014
If I understand correctly, all translations done in branches and docs
build from branches. So it is safe to remove po files from master.
>From master only testing docs built and it has no translations.
2014-03-28 13:20 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> But if you remove all languages except english from the master branch
> you would not be able to build ALL languages in one go on one checkout
> without the need of switching branches .. which I think we need on the
> main server to deploy the documentation ..
> Probably there is an easy way to script the branch switching but I am
> not sure if it isn't easier to just leave the translations in master
> Or am I wrong here?
> regards
> Werner
> On Fri, Mar 28, 2014 at 10:19 AM, Alexander Bruy
> <alexander.bruy at gmail.com> wrote:
>> Hi all,
>> if I'm not wrong we decided that all translation work on documentation
>> is done in branches. Maybe we can remove all .po files except English
>> from master branch?
>> Alexander Bruy
>> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Alexander Bruy
More information about the Qgis-community-team
