[Qgis-community-team] Update translation for training
Richard Duivenvoorde
richard at duif.net
Sat Oct 11 14:10:45 PDT 2014
On 11-10-14 22:26, Yves Jacolin wrote:
> Le samedi 11 octobre 2014, 21:50:09 Richard Duivenvoorde a écrit :
>>> I built fr documentation with sucess and I can't see any problem.
>>> Frontpage
>>> for french translation shows that the last build was today around 17h00.
>>> Did you work on this before me?
>> Nope, but I think somebody else fixed a translation that gave the problem?
>> Hope all is fine now.
>> Regards,
>> Richard
> hum, but I forget to said that some chapter are not translated both in my
> local build and in the website but they have been translated in transifex (see
> trainings manual > Creator vector file > Actions
> http://docs.qgis.org/2.2/fr/docs/training_manual/create_vector_data/actions.html
> And there is a problem with the release number, isn't it? Should it be 2.4?
Release number is still 2.2 because the docs had not been updated for
2.4 but we will probably release a new 2.6(!) version around the QGIS
2.6 release.
About the french build problem:
http://docs.qgis.org/2.2/fr/docs/ still shows 25 sept.
But the github translations are behind with the transifex translations.
Transifex holds the latest version, and the scripts build based on the
latest transifex version by pulling the latest version via the
tx-command line tool (see the make file).
So can only reproduce the problem if you take the latest version from
transifex, OR somebody pulls and puts in it Github...
I just pulled all translations from transifex and pushed them to github,
so now your build should fail :-)
Hope this helps,
Regards,
More information about the Qgis-community-team
