[Qgis-community-team] help for tutorial
Marc Hermitte
marchermitte at gmail.com
Fri Sep 4 03:21:59 PDT 2015
Hello!
I'm teaching 3D and I'm currently producing a tutorial about making a city
in Modo.
Trying different approaches, one of them involves the use of OSM infos to
produce street and building blocks polygons to use as a base for extruding
or instancing pre-made buildings over a base geometry.
I'm having a hard time getting what I need from QGIS, I'm sure there is a
way but the infos I find aren't directed to 3D users.
I'm trying to pull the vectors from the map and export as dxf but I get
unusable results.
Is there a workflow to capture streets and blocks layers for instance and
export them as 3D meshes that I can import in my 3D package?
Thank you!
Marc Hermitte
DigitArt
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20150904/ac469ce6/attachment.html>
More information about the Qgis-community-team
