[Qgis-community-team] help for tutorial
Richard Duivenvoorde
richard at duif.net
Sun Sep 6 11:17:33 PDT 2015
Hi Marc,
I think it is better to address this question to the QGIS-user list.
This (rather small) list is mostly used for community related stuff.
For what I know we just introduced the 3d knowledge into our geometries,
so I do not think you can get 3d-aware data out of QGIS easily.
But 2d contours of roads and houses should be possible, and I've seen
people stretching those up based on DEM or other height models.
But as said, try the user list..
Regards,
On 04-09-15 12:21, Marc Hermitte wrote:
> Hello!
> I'm teaching 3D and I'm currently producing a tutorial about making a
> city in Modo.
> Trying different approaches, one of them involves the use of OSM infos
> to produce street and building blocks polygons to use as a base for
> extruding or instancing pre-made buildings over a base geometry.
> I'm having a hard time getting what I need from QGIS, I'm sure there is
> a way but the infos I find aren't directed to 3D users.
> I'm trying to pull the vectors from the map and export as dxf but I get
> unusable results.
> Is there a workflow to capture streets and blocks layers for instance
> and export them as 3D meshes that I can import in my 3D package?
> Thank you!
> Marc Hermitte
> DigitArt
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
