[Qgis-community-team] QGIS 2.14 doc available only in english?
Yves Jacolin yjacolin at free.fr
Thu Aug 4 01:18:49 PDT 2016
On Wednesday, July 27, 2016 17:57:57 Richard Duivenvoorde wrote:
> On 27-07-16 11:56, Yves Jacolin wrote:
> > I tried with docker but I get only english string in the fr directory.
> > I guess I have to pull transifex string, isn't?
> Hi Yves,
> see:
> https://github.com/qgis/QGIS-Documentation/blob/manual_en_2.14/docker-world.
> sh#L29
> langs=fr ./docker-world.sh
> should work...
> Note that ( I think ) you need a .transifexrc with your credentials in
> your home directory, as it is copied into the container to pull the
> strings from transifex
> https://github.com/qgis/QGIS-Documentation/blob/manual_en_2.14/docker-run.sh
> #L7
> also note that it will try to build both pdf and html AND try to sync
> the result to qgis.org.... (which will fail unless you have a key for
> it....)
> Let me know if this works...
> Regards,
Richard,
It fails with this message:
> Warning, treated as error:
> /site/source/site/forusers/support.rst:60: WARNING: inconsistent term
references in translated message
Looking at transifex, all seems correct but you changed the string 15 days
ago. Does it meant that my translation files are not uptodate?
I have a ~/.transifexrc file.
Thanks,
Y.
More information about the Qgis-community-team mailing list
