[Qgis-community-team] manual build
DelazJ
delazj at gmail.com
Thu Aug 4 01:27:55 PDT 2016
Otto, I think you need to build the language from Github source (
https://github.com/qgis/QGIS-Documentation/blob/master/readme.rst),
identify each of the warnings/errors that would be displayed during the
build and then fix them in Transifex (or source code?).
Isn't there in Transifex a way to identify those errors/warnings? I find
this page http://docs.transifex.com/setup/setting-translation-checks/ to
set up warning and errors rules. Are all the possible settings we need
activated? Then, if a translator ignores the warning, is there a way in
Transifex to find those translations? I think this will really improve the
builds fixes (I personally failed again to build the doc on the same W10
laptop that builds it months ago).
Regards,
Harrissou
2016-08-04 10:07 GMT+02:00 Otto Dassau <otto at qgis.org>:
> Hi Richard,
> and where can I follow, if a language builds or not to fix it. Can I find
> it
> here: https://travis-ci.org/qgis/QGIS-Documentation/branches
> Regards
> Otto
> Am Thu, 4 Aug 2016 09:45:00 +0200
> schrieb Richard Duivenvoorde <rdmailings at duif.net>:
> > On 04-08-16 08:29, Otto Dassau wrote:
> > > Hi Richard,
> > > how often does the manual currently build? And is it correct, that
> people
> > > can start to translate in transifex now?
> > Documentation 2.14 build is started once a day. But currently only dutch
> > and english and one or two others are rebuilding without warnings/errors.
> > To be able to have at least all languages I temporarily disabled that
> > the build stops on a warning/error and created all languages on 31th of
> > july, see footer with last build date on frontpage:
> > http://docs.qgis.org/2.14/en/docs/index.html
> > But most languages have errors/warnings and do not get updated after the
> > 31th because of the translation errors.
> > But it takes me too much time to fix all those by hand myself. I hope
> > that language coordinators will take up this task.
> > So: Yes, people can start translating again 2.14
> > But note the last build line in the bottom of
> > http://docs.qgis.org/2.14/de/docs/index.html
> > First the build should be fixed ( by fixing some translations that break
> > the german build ).
> > Regards,
> > Richard
> > cc to community list too
> > Qgis-community-team mailing list for organizing community resources such
> > as documentation, translation etc.. Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Otto Dassau
> QGIS Project Steering Committee Member
> otto at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160804/dc34c034/attachment.html>
More information about the Qgis-community-team
