[Qgis-community-team] manual build
Otto Dassau
otto at qgis.org
Thu Aug 4 02:03:21 PDT 2016
I don't see where to set up warning and error rules for transifex
according to the help page, but I see that I am not an administrator
https://www.transifex.com/qgis/public/ - maybe thats's why.
Can any of the transifex admins have a look?
I will try to build it locally now - thanks!
Regards,
Otto
Am Thu, 4 Aug 2016 10:27:55 +0200
schrieb DelazJ <delazj at gmail.com>:
> Hi,
> Otto, I think you need to build the language from Github source (
> https://github.com/qgis/QGIS-Documentation/blob/master/readme.rst),
> identify each of the warnings/errors that would be displayed during the
> build and then fix them in Transifex (or source code?).
> Isn't there in Transifex a way to identify those errors/warnings? I find
> this page http://docs.transifex.com/setup/setting-translation-checks/ to
> set up warning and errors rules. Are all the possible settings we need
> activated? Then, if a translator ignores the warning, is there a way in
> Transifex to find those translations? I think this will really improve the
> builds fixes (I personally failed again to build the doc on the same W10
> laptop that builds it months ago).
> Regards,
> Harrissou
> 2016-08-04 10:07 GMT+02:00 Otto Dassau <otto at qgis.org>:
> > Hi Richard,
> > and where can I follow, if a language builds or not to fix it. Can I find
> > it
> > here: https://travis-ci.org/qgis/QGIS-Documentation/branches
> > Regards
> > Otto
> > Am Thu, 4 Aug 2016 09:45:00 +0200
> > schrieb Richard Duivenvoorde <rdmailings at duif.net>:
> > > On 04-08-16 08:29, Otto Dassau wrote:
> > > > Hi Richard,
> > > > how often does the manual currently build? And is it correct, that
> > people
> > > > can start to translate in transifex now?
> > > Documentation 2.14 build is started once a day. But currently only
> > > dutch and english and one or two others are rebuilding without
> > > warnings/errors.
> > > To be able to have at least all languages I temporarily disabled that
> > > the build stops on a warning/error and created all languages on 31th of
> > > july, see footer with last build date on frontpage:
> > > http://docs.qgis.org/2.14/en/docs/index.html
> > > But most languages have errors/warnings and do not get updated after
> > > the 31th because of the translation errors.
> > > But it takes me too much time to fix all those by hand myself. I hope
> > > that language coordinators will take up this task.
> > > So: Yes, people can start translating again 2.14
> > > But note the last build line in the bottom of
> > > http://docs.qgis.org/2.14/de/docs/index.html
> > > First the build should be fixed ( by fixing some translations that
> > > break the german build ).
> > > Regards,
> > > Richard
> > > cc to community list too
> > > _______________________________________________
> > > Qgis-community-team mailing list for organizing community resources
> > > such as documentation, translation etc..
> > > Qgis-community-team at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> > Otto Dassau
> > QGIS Project Steering Committee Member
> > otto at qgis.org
> > Qgis-community-team mailing list for organizing community resources such
Otto Dassau
otto at qgis.org
More information about the Qgis-community-team
