[Qgis-community-team] manual build
Richard Duivenvoorde
rdmailings at duif.net
Thu Aug 4 02:05:42 PDT 2016
On 04-08-16 10:07, Otto Dassau wrote:
> Hi Richard,
> and where can I follow, if a language builds or not to fix it. Can I find it
> here: https://travis-ci.org/qgis/QGIS-Documentation/branches
No, in travis only the english versions are build, without the pulling
of translations and taking them into account.
You need to build locally (or on qgis2 server) to see the errors.
Easiest if you remove the -W option from the build, then you can see all
warnings in one go:
https://github.com/qgis/QGIS-Documentation/blob/manual_en_2.14/Makefile#L86
You can either build in a Virtual env on a linux machine:
make full LANG=de
or in Docker (you may have to commit the removal of the -W because it
will get stashed/dropped I think):
langs=en ./docker-world.sh
These are current german errors
source/docs/gentle_gis_introduction/vector_data.rst:20: WARNING:
inconsistent references in translated message
source/docs/user_manual/introduction/qgis_gui.rst:134: ERROR: Undefined
substitution referenced: "mActionToggleEditing".
source/docs/user_manual/plugins/plugins_evis.rst:58: ERROR: Undefined
substitution referenced: "event_browser".
source/docs/user_manual/plugins/plugins_georeferencer.rst:180: WARNING:
Inline strong start-string without end-string.
source/docs/user_manual/plugins/plugins_heatmap.rst:125: WARNING: Inline
literal start-string without end-string.
source/docs/user_manual/preamble/conventions.rst:31: ERROR: Undefined
substitution referenced: "mActionAddRasterLayer".
source/docs/user_manual/preamble/features.rst:162: WARNING: inconsistent
term references in translated message
source/docs/user_manual/processing/console.rst:270: WARNING: Inline
source/docs/user_manual/processing_algs/saga/grid_tools.rst:470:
WARNING: Inline interpreted text or phrase reference start-string
without end-string.
without end-string.
source/docs/user_manual/working_with_vector/vector_properties.rst:1455:
WARNING: Inline strong start-string without end-string.
Note that you have to lookup those lines in Transifex, as the
translation is making it fail
Regards,
Richard
More information about the Qgis-community-team
