[Qgis-community-team] QGIS 2.14 doc available only in english?
DelazJ
delazj at gmail.com
Thu Aug 4 09:44:13 PDT 2016
Wow, looks like you found new ones.
/home/richard/dev/qgis/git/QGIS-Documentation-2.14/source/docs/user_manual/
introduction/qgis_configuration.rst:593:
WARNING: undefined label: label_statusbar (if the link has no caption
the label must precede a section header)
This one sounds like something out of Transifex control. And can't confirm
looking at GitHub.
source/docs/user_manual/index.rst:15:
WARNING: toctree contains reference to nonexisting document
u'docs/user_manual/processing_algs/index'
Sounds like source code contains a processing_algs folder (with underscore)
while in Transifex the folder seems to be processing-algs (with hyphen)
plugins/plugins_evis.rst:280:
WARNING: inconsistent term references in translated message
This one is an error in source file (ref: instead of :ref: used in french
translation). I already fix source so will require a new push
plugins/plugins_evis.rst:361:
WARNING: Inline strong start-string without end-string.
Couldn't find this line number in Tx :'(
Hope that all is done now!
Another rebuild, please?
2016-08-04 16:27 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 04-08-16 15:53, DelazJ wrote:
> > Hi,
> > Thanks Richard for the list. I tried to address them but may have
> > overlooked a couple of them. Could you (or someone else) please (no
> > hurry!!) try to build and let us know if there are still issues?
> Current status:
> /home/richard/dev/qgis/git/QGIS-Documentation-2.14/source/docs/gentle_gis_
> introduction/coordinate_reference_systems.rst:383:
> WARNING: inconsistent references in translated message
> source/docs/training_manual/appendix/contribute.rst:101:
> WARNING: Inline interpreted text or phrase reference start-string
> without end-string.
> without end-string.
> source/docs/user_manual/plugins/plugins_evis.rst:361:
> source/docs/user_manual/plugins/plugins_evis.rst:280:
> source/docs/user_manual/working_with_ogc/ogc_client_support.rst:245:
> source/docs/user_manual/working_with_vector/attribute_table.rst:22:
> ERROR: Undefined substitution referenced: "mActionOpenTable".
> source/docs/user_manual/working_with_vector/attribute_table.rst:48:
> ERROR: Undefined substitution referenced: "mActionToggleEditing".
> source/docs/user_manual/working_with_vector/attribute_table.rst:50:
> ERROR: Undefined substitution referenced: "mActionSaveEdits".
> source/docs/user_manual/working_with_vector/vector_properties.rst:466:
> without end-string.
> without end-string.
> looking for now-outdated files... none found
> pickling environment... done
> checking consistency... done
> preparing documents... done
> writing output... [100%]
> docs/user_manual/working_with_vector/virtual_layers
> source/docs/user_manual/introduction/qgis_configuration.rst:593:
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20160804/4a5d02ee/attachment.html>
More information about the Qgis-community-team
